Group: DynoMotion Message: 1521 From: bradodarb Date: 7/19/2011
Subject: Interpreter Interpretations....
Hello Tom,
I am planning to taske advantage of some down time here after the AWFS show while I'm in the hotel this week. I brought my Kflop test rig so I can play around with some interpreter stuff.
Off the bat, I am wondering if the same Motion Params used for CCoordMotion.cpp is used for the Interpreter.cpp MotionParams. I am hoping that I can set them all from one place, but either way if I know about it I can make it happen.
Also, can I populate the tool and setup data structures from code rather than from a file? I would like to create som XML's for these two purposes. I did not immediately find the data structutres, but I will dig a bit depper later today and see what you are doing with them.
Thanks for your time,
Brad Murry
Group: DynoMotion Message: 1523 From: Tom Kerekes Date: 7/19/2011
Subject: Re: Interpreter Interpretations....
Hi Brad,
Yes the MOTION_PARAMS are part of the Kinematics object, which is part of the CoordMotion object, which becomes part to the Interpreter object.
Yes you can populate the parameters from code.  The KMotionCNC stores them in a text file in the data directory as GCodeConfigCNC.txt.  Your app can save and restore them however you wish.
--- On Tue, 7/19/11, bradodarb <bradodarb@...> wrote:
Subject: [DynoMotion] Interpreter Interpretations....
Date: Tuesday, July 19, 2011, 12:19 PM
Hello Tom,
Brad Murry
Group: DynoMotion Message: 1593 From: bradodarb Date: 7/29/2011
Hello Tom,
I am implementing the interpreter today and although some of the public members below seem intuitive, I would like to make sure I have everything right. Can you give me brief descripts on each member and tell me whether you think they should be exposed as properties or not?
bool m_InitializeOnExecute;
bool m_ReadToolFile;
int m_start, m_end;
bool m_Resume;
double m_ResumeSafeZ;
int m_ResumeSafeRelAbs;
BOOL m_ResumeMoveToSafeZ;
BOOL m_ResumeTraverseXY;
double m_ResumeTraverseSafeX;
double m_ResumeTraverseSafeY;
BOOL m_ResumeSafeStartSpindle;
int m_ResumeSafeSpindleCWCCW;
BOOL m_ResumeDoSafeFeedZ;
double m_ResumeFeedSafeZ;
double m_ResumeResumeFeedRate;
double m_ResumeZFeedRate;
BOOL m_ResumeRestoreFeedRate;
Brad Murry
Group: DynoMotion Message: 1594 From: Tom Kerekes Date: 7/29/2011
See below
Date: Friday, July 29, 2011, 11:52 AM
Hello Tom,
bool m_InitializeOnExecute; don't export
bool m_ReadToolFile;obsolete - always reads
int m_start, m_end;obsolete - unused
After a Halt and a possible Tool replacement or Offset change
there is a mechanism to "Resume"
bool m_Resume;  Set if any part of the resume sequence is desired
double m_ResumeSafeZ; Safe Z height to be raised to
int m_ResumeSafeRelAbs;  Specifies if the Z heights are absolute or relative
BOOL m_ResumeMoveToSafeZ;  Specifies whether or not the Z should be first moved up
BOOL m_ResumeTraverseXY;  Specifies whether an xy motion should be made back to some position
double m_ResumeTraverseSafeX;  Position in X
double m_ResumeTraverseSafeY;  Position in Y
BOOL m_ResumeSafeStartSpindle; Specifies if the Spindle should be re-started
int m_ResumeSafeSpindleCWCCW;  Specifies Spindle direction if it is to be re-started
BOOL m_ResumeDoSafeFeedZ;  Specifies if the Z should then be fed down to some height
double m_ResumeFeedSafeZ;  Specifies height Z should be fed down to
double m_ResumeResumeFeedRate;  double m_ResumeZFeedRate;Specifies Rate at which feed rate should be restored to
BOOL m_ResumeRestoreFeedRate; Specifies whether or not the specified feed rate should be restored
Brad Murry
Group: DynoMotion Message: 1595 From: bradodarb Date: 7/29/2011
Excellent Tom- Thanks!
I do have a concern and a few more methods to clarify...
I may have mentioned before that I wish to directly set all setup params and tool tables. Will this impede my intentions?
Also, are there any other pitfalls I may run into while trying to set params you are normally using a file for from memory?
In case you are interested as to why I do not want to use the existing file formats:
The plan is to have .net classes that contain all the data memebers dor things like tools and also the members in setup_struct.
This will allow me to serialize and de-serialize using XML so there is no manual parsing required by my application. I am also using these data classes for MVVM, so they are all implementing INotifyPropertyChanged.
Ok, so that is a concern, here are some remaining members I am not quite sure about:
MCODE_ACTION McodeActions[MAX_MCODE_ACTIONS];
int ExecutePC(const char *Name);
char ToolFile[MAX_PATH];
char SetupFile[MAX_PATH];
char GeoFile[MAX_PATH];
CCoordMotion CoordMotion; -- There is only one CoordMotion object per board, right?
int m_CurrentLine;
int m_GCodeReads;
CString m_InFile; Gcode File?
int m_exitcode;
int DoExecute();
int DoExecuteComplete();
I think after this I will have some questions on some members in the setup_struct...
Thank you for your time, I think this is the last thing I need to wrap!
-Brad Murry
> See below
> Hello Tom,
> Thanks,
> Brad Murry
Group: DynoMotion Message: 1596 From: Tom Kerekes Date: 7/29/2011
See below
Subject: [DynoMotion] Re: Interpreter Interpretations....
Date: Friday, July 29, 2011, 12:36 PM
If the filenames are not set (they default to NULL) then they will not be read
MCODE_ACTION McodeActions[MAX_MCODE_ACTIONS];  MCodes(in GCode) can be configured to do various "Actions" such as Set/Clear a bit, Run a C Program in KFLOP, Run a Windows Program, etc.  This structure defines what is to be performed for various M Codes.  User Buttons also use this mechanism as "pseudo M codes" and so can be configured to do likewise "Actions"
Calling this spawns a Windows PC Application by the specified name
char ToolFile[MAX_PATH];  Can be used to define Tool Parameters
char SetupFile[MAX_PATH];  Can be used to define inital Interpreter Settings
char GeoFile[MAX_PATH];  Can be used to define a 2.5D Geometric correction file
CCoordMotion CoordMotion; -- There is only one CoordMotion object per board, right? Yes
These below are all for internal Interpreter use only
int m_CurrentLine;
int m_GCodeReads;
int m_exitcode;
int DoExecute();
I've heard that before :}
-Brad Murry
> See below
> Hello Tom,
> Thanks,
> Brad Murry
Group: DynoMotion Message: 1597 From: bradodarb Date: 7/29/2011
"Thank you for your time, I think this is the last thing I need to wrap!
I've heard that before :} "
Ha!, I should clarify that what I meant is : the Interpreter is the last thing I plan to wrap - I'm sure there will be many clarifications needed down the road epecially once I get this thing connected to a real world machine.
There are too many assumptions I have used in implementing everything (for the sake of progress), and I think I may email you the source first so you can tell me if it is on the right track - plus there are likely a lot of members that may not need to be/should not be exported. Once you approve of the exported members and such I will release the source publicly. Sound like a plan?
-Brad Murry
> See below
> int m_CurrentLine;
> int m_GCodeReads;
> int m_exitcode;
> int DoExecute();
> Thanks
> -Brad Murry
> > See below
> > --- On Fri, 7/29/11, bradodarb <bradodarb@> wrote:
> > Hello Tom,
> > Thanks,
> > Brad Murry
Group: DynoMotion Message: 1598 From: bradodarb Date: 7/29/2011
I see some of the setup params are not commented(mut most are)
Can you clarify these?:
ON_OFF block_delete;
int cutter_radius_compensation;
double cycle_z;
int current_line;
fpos_t sub_stack_pos[MAX_SUB_STACK];
fpos_t sub_stack_sub_start_pos[MAX_SUB_STACK];
int sub_stack_lineno[MAX_SUB_STACK];
int sub_stack_sub_start_lineno[MAX_SUB_STACK];
int sub_stack_call_cnt[MAX_SUB_STACK];
int stacki;
Thank you,
-Brad Murry
> -Brad Murry
> > See below
> > int m_CurrentLine;
> > int m_GCodeReads;
> > int m_exitcode;
> > int DoExecute();
> > Thanks
> > -Brad Murry
> > > See below
> > > Hello Tom,
> > > Thanks,
> > > Brad Murry
Group: DynoMotion Message: 1599 From: bradodarb Date: 7/29/2011
Hello,
Int the case of:
int tool_table_index; // tool index used with cutter comp
double tool_length_offset; // current tool length offset
int length_offset_index; // for use with tool length offsets
and
double cutter_comp_radius; // current cutter compensation radius
How do these values interact/override each other?
Are some of them to be considered read only, or can I override values pulled from tool_table_index and length_offset_index
by updating the tool_length_offset and cutter_comp_radius?
Just trying to get my head wrapped 'round it all.
-Brad Murry
> Tom,
> double cycle_z;
> int current_line;
> int stacki;
> Thank you,
> -Brad Murry
> > -Brad Murry
> > > See below
> > > int m_CurrentLine;
> > > int m_GCodeReads;
> > > int m_exitcode;
> > > int DoExecute();
> > > Thanks
> > > -Brad Murry
> > > > See below
> > > > TK
> > > > Hello Tom,
> > > > Thanks,
> > > > Brad Murry
Group: DynoMotion Message: 1600 From: bradodarb Date: 7/29/2011
Sorry for the constant deluge.....
I am confused by a common pair of variables I see throughout coordmotion and interpreter
Sequence and ID
What are they used for and what is the diff?
-Brad Murry
> Hello,
> Int the case of:
> and
> Thanks,
> -Brad Murry
> > Tom,
> > double cycle_z;
> > int current_line;
> > int stacki;
> > Thank you,
> > -Brad Murry
> > > -Brad Murry
> > > > See below
> > > > int m_CurrentLine;
> > > > int m_GCodeReads;
> > > > int m_exitcode;
> > > > int DoExecute();
> > > > Thanks
> > > > TK
> > > > -Brad Murry
> > > > > See below
> > > > > TK
> > > > > Hello Tom,
> > > > > Thanks,
> > > > > Brad Murry
Group: DynoMotion Message: 1601 From: Tom Kerekes Date: 7/29/2011
Hi Brad,
These are internal Interpreter variables so I'm not sure how necessary it is to document them.  The G Code Interpereter was derive from the Public Domain EMC Interpreter so much of it wasn't written by Dynomotion.  I will try to briefly describe them where I can:
Date: Friday, July 29, 2011, 2:58 PM
int cutter_radius_compensation;  whether or no cutter compensation is on
double cycle_z;
int current_line;  current GCode line number
Stacks used with regard to GCode subroutine calls and loops
int stacki;
Thank you,
-Brad Murry
> -Brad Murry
> > See below
> > int m_CurrentLine;
> > int m_GCodeReads;
> > int m_exitcode;
> > int DoExecute();
> > Thanks
> > -Brad Murry
> > > See below
> > > Hello Tom,
> > > Thanks,
> > > Brad Murry
Group: DynoMotion Message: 1602 From: Tom Kerekes Date: 7/29/2011
Hi Brad,
Again I think most of these are used internally.  For example to change the Tool Index the User would execute a Hxx command in G Code.  However KMotionCNC does display some settings on the screen like current tool and allows the User to change the tool directly, but I think it simulates GCode to effect the change rather than modifying the internal variables.
Date: Friday, July 29, 2011, 3:40 PM
Hello,
Int the case of:
and
-Brad Murry
> Tom,
> double cycle_z;
> int current_line;
> int stacki;
> Thank you,
> -Brad Murry
> > -Brad Murry
> > > See below
> > > int m_CurrentLine;
> > > int m_GCodeReads;
> > > int m_exitcode;
> > > int DoExecute();
> > > Thanks
> > > -Brad Murry
> > > > See below
> > > > TK
> > > > Hello Tom,
> > > > Thanks,
> > > > Brad Murry
Group: DynoMotion Message: 1603 From: bradodarb Date: 7/29/2011
I see, so perhaps some/all setup params should be made as "read only"(only provide get value functions) when I export?
" I think it simulates GCode to effect the change rather than modifying the internal variables"
Does this mean it drops it into MDI mode and makes the calls and then back? I guess I would be able to tell in the code...
Thanks again,
-Brad Murry
> Hi Brad,
> Hello,
> Int the case of:
> and
> Thanks,
> -Brad Murry
> > Tom,
> > double cycle_z;
> > int current_line;
> > int stacki;
> > Thank you,
> > -Brad Murry
> > > -Brad Murry
> > > > See below
> > > > int m_CurrentLine;
> > > > int m_GCodeReads;
> > > > int m_exitcode;
> > > > int DoExecute();
> > > > Thanks
> > > > TK
> > > > -Brad Murry
> > > > > See below
> > > > > TK
> > > > > Hello Tom,
> > > > > Thanks,
> > > > > Brad Murry
Group: DynoMotion Message: 1604 From: Tom Kerekes Date: 7/29/2011
As far as CoordMotion class is concerned Sequence number and ID they are just two arbitrary pieces of information that the caller (normally a Gcode Interpreter) passed in with entered path calls (arcs and lines), and passed through and kept associated with Trajectory Planner Motion Segments, so that in the event of a Halt, the Library can determine which segment we halted within and determine the corresponding Sequence Number an ID.  Realize that the Application generating the motion needs to be working seconds ahead of the actual machine tool which could easily be thousands of segments behind.  So if a Halt occurs the Application is likely to want to rewind back to the place that was actually executed last.  So the Sequence Number and ID can be used to identify what point the application needs to return to to re-sync with the actual current halted machine tool position.
Realize that sometimes multiple pieces of path that are passed in might be combined together into a single motion segment if they are tiny or collinear for example.  Conversely a single piece of path may be broken into multiple segments for various reasons such as it would take excessively long to execute or needs to be non-linearly corrected at more than just the end points.  Or if 3D facet rounding is performed.
With regard to the G Code Interpreter we basically want to return to the line of GCode that created the motion where we Halted.  Passing the GCode line number through all the processes doesn't work well because of subroutine calls in the GCode.  Rewinding thousands of GCode lines might loop backwards through the same G Code line multiple times but with the Interpreter in a different state each time.  So instead a unique "Sequence" Number is used that simply increments for each GCode Block.
Furthermore simply returning to the correct line of GCode is not sufficient to know how to resume and correctly advance to the next line of GCode from that point.  This is because in some cases several operations are created by a single line of Gcode mainly because of tool radius compensation.  For example with compensation on, to cut a rectangle (which is defined by a rectangle with 4 G1 commands), 4 lines and 4 arcs are actually needed.  The ID code is used in these cases to know which phase of the GCode block to properly reset the Interpreter back to.
If you are using our Interpreter all this functionality should be handled automatically for you without having to worry about it.
Date: Friday, July 29, 2011, 4:15 PM
Sequence and ID
-Brad Murry
> Hello,
> Int the case of:
> and
> Thanks,
> -Brad Murry
> > Tom,
> > double cycle_z;
> > int current_line;
> > int stacki;
> > Thank you,
> > -Brad Murry
> > > -Brad Murry
> > > > See below
> > > > int m_CurrentLine;
> > > > int m_GCodeReads;
> > > > int m_exitcode;
> > > > int DoExecute();
> > > > Thanks
> > > > TK
> > > > -Brad Murry
> > > > > See below
> > > > > TK
> > > > > Hello Tom,
> > > > > Thanks,
> > > > > Brad Murry
Group: DynoMotion Message: 1605 From: Tom Kerekes Date: 7/29/2011
Yes.  If you search in KMotionCNC if the User clicks on the MM or inch Radio buttons it calls:
void
CKMotionCNCDlg::Onmm()
    DoGCodeLine(
"G21");
void
CKMotionCNCDlg::Oninch()
    DoGCodeLine(
"G20");
Which creates a 1 line GCode File and executes it like the MDI.
Date: Friday, July 29, 2011, 4:32 PM
Thanks again,
-Brad Murry
> Hi Brad,
> Hello,
> Int the case of:
> and
> Thanks,
> -Brad Murry
> > Tom,
> > double cycle_z;
> > int current_line;
> > int stacki;
> > Thank you,
> > -Brad Murry
> > > -Brad Murry
> > > > See below
> > > > int m_CurrentLine;
> > > > int m_GCodeReads;
> > > > int m_exitcode;
> > > > int DoExecute();
> > > > Thanks
> > > > TK
> > > > -Brad Murry
> > > > > See below
> > > > > TK
> > > > > Hello Tom,
> > > > > Thanks,
> > > > > Brad Murry
Group: DynoMotion Message: 1606 From: bradodarb Date: 7/29/2011
Thanks for such a detailed response.
As you know, I am trying to do an exhaustive implementation of your powerful library in c#, and it looks like I am getting carried away in places; mostly due to my profound ignorance in using your product. It is completely different than what I am used to - and that is a great thing. This is why I requested for you to review the wrappers before I release the source.
I think I am usng it correctly in my AxisGroup object, where when a list of geometry is passed into the coord motion, all elements (lines, points, arcs) are given the same sequence number for each list and each element in a given list is given an ID that is incremented from zero to list length as they are added.
From there I should be able to track back to the list and element in that list on a halt.
Does this sound reasonable?
-Brad Murry
> HTH
> Sequence and ID
> -Brad Murry
> > Hello,
> > Int the case of:
> > and
> > Thanks,
> > -Brad Murry
> > > Tom,
> > > double cycle_z;
> > > int current_line;
> > > int stacki;
> > > Thank you,
> > > -Brad Murry
> > > > -Brad Murry
> > > > > See below
> > > > > int m_CurrentLine;
> > > > > int m_GCodeReads;
> > > > > int m_exitcode;
> > > > > int DoExecute();
> > > > > Thanks
> > > > > TK
> > > > > -Brad Murry
> > > > > > See below
> > > > > > TK
> > > > > > Hello Tom,
> > > > > > Thanks,
> > > > > > Brad Murry
Group: DynoMotion Message: 1608 From: bradodarb Date: 7/29/2011
I saw that, and my first response is...really? I realize this is a potential
issue with the EMC and I am not knocking DM. It just seems to be a odd way to
go about it.
Is it absolutely necesary to create a file?
Anyone else here doing this?
Andrew Erwwod, how did you handle this(assuming you did) in your
implementation?
-Brad Murry
> void CKMotionCNCDlg::Onmm()
>     DoGCodeLine("G21");
> void CKMotionCNCDlg::Oninch()
>     DoGCodeLine("G20");
> Thanks again,
> -Brad Murry
> > Hi Brad,
> > Hello,
> > Int the case of:
> > and
> > Thanks,
> > -Brad Murry
> > > Tom,
> > > double cycle_z;
> > > int current_line;
> > > int stacki;
> > > Thank you,
> > > -Brad Murry
> > > > -Brad Murry
> > > > > See below
> > > > > int m_CurrentLine;
> > > > > int m_GCodeReads;
> > > > > int m_exitcode;
> > > > > int DoExecute();
> > > > > Thanks
> > > > > TK
> > > > > -Brad Murry
> > > > > > See below
> > > > > > TK
> > > > > > ÃÆ'‚
> > > > > > Hello Tom,
> > > > > > bool m_InitializeOnExecute;ÃÆ'‚ don't exportÃÆ'‚
> > > > > > ÃÆ'‚
> > > > > > bool m_Resume;ÃÆ'‚  Set if any partÃÆ'‚ of theÃÆ'‚ resume sequence is desired
> > > > > > double m_ResumeSafeZ; Safe Z height to be raised toÃÆ'‚
> > > > > > int m_ResumeSafeRelAbs;ÃÆ'‚  Specifies if the Z heights are absolute or relative
> > > > > > BOOL m_ResumeMoveToSafeZ;ÃÆ'‚  Specifies whether or not the Z should be first moved up
> > > > > > BOOL m_ResumeTraverseXY;ÃÆ'‚  Specifies whether an xy motion should be made back to some position
> > > > > > double m_ResumeTraverseSafeX;ÃÆ'‚  Position in X
> > > > > > double m_ResumeTraverseSafeY;ÃÆ'‚  Position in Y
> > > > > > int m_ResumeSafeSpindleCWCCW;ÃÆ'‚  Specifies Spindle direction if it is to be re-started
> > > > > > BOOL m_ResumeDoSafeFeedZ;ÃÆ'‚  Specifies if the Z should then be fed down to some height
> > > > > > double m_ResumeFeedSafeZ;ÃÆ'‚  Specifies height Z should be fed down to
> > > > > > double m_ResumeResumeFeedRate;ÃÆ'‚  double m_ResumeZFeedRate;Specifies Rate at which feed rate should be restored to
> > > > > > Thanks,
> > > > > > Brad Murry
Group: DynoMotion Message: 1609 From: bradodarb Date: 7/29/2011
Having a look at
rs274ngc.cpp
This could be good ;) , it looks like it is using the settings inside the methods.
Anyone willing to test some of this out?
I guess I can overwrite the current DoGCodeLine and see if it affects my axis positions....
-Brad
> go about it.
> implementation?
> -Brad Murry
> >     DoGCodeLine("G21");
> >     DoGCodeLine("G20");
> > Thanks again,
> > -Brad Murry
> > > Hi Brad,
> > > Hello,
> > > Int the case of:
> > > and
> > > Thanks,
> > > -Brad Murry
> > > > Tom,
> > > > double cycle_z;
> > > > int current_line;
> > > > int stacki;
> > > > Thank you,
> > > > -Brad Murry
> > > > > -Brad Murry
> > > > > > See below
> > > > > > int m_CurrentLine;
> > > > > > int m_GCodeReads;
> > > > > > int m_exitcode;
> > > > > > int DoExecute();
> > > > > > Thanks
> > > > > > TK
> > > > > > -Brad Murry
> > > > > > > See below
> > > > > > > TK
> > > > > > > ÃÆ'‚
> > > > > > > Hello Tom,
> > > > > > > ÃÆ'‚
> > > > > > > Thanks,
> > > > > > > Brad Murry
Group: DynoMotion Message: 1610 From: bradodarb Date: 7/29/2011
Answering my own post again... This is why I need to hoook my board up to a proper machine. Maybe I will look into resurrecting and old project of mine so I can prove this stuff out without bogging down support.
Anywho-
I am hoping someone else can confirm, but it definitely appears that changing the settings values while running will have an immediate effect. I think in my actual CNC application I will limit which commands can be issued depending on the current modal situation, but I will make them get/sets for a robust implementation.
I just put these lines at the beginning of
void CKMotionCNCDlg::OnSend()
in KMotionCNC.sln
Interpreter.p_setup->tool_length_offset = 23;
Interpreter.p_setup->plane = 2;
And I saw the Z increase immediately by 23 and my next arc call yeilded an error because of the plane change.
Anyone caring to explore this further please let me know your findings.
I will see what people think over at the EMC forum as well.
-Brad Murry
> Having a look at
> rs274ngc.cpp
> -Brad
> > go about it.
> > implementation?
> > -Brad Murry
> > >     DoGCodeLine("G21");
> > >     DoGCodeLine("G20");
> > > Thanks again,
> > > -Brad Murry
> > > > Hi Brad,
> > > > TK
> > > > Hello,
> > > > Int the case of:
> > > > and
> > > > Thanks,
> > > > -Brad Murry
> > > > > Tom,
> > > > > double cycle_z;
> > > > > int current_line;
> > > > > int stacki;
> > > > > Thank you,
> > > > > -Brad Murry
> > > > > > -Brad Murry
> > > > > > > See below
> > > > > > > int m_CurrentLine;
> > > > > > > int m_GCodeReads;
> > > > > > > int m_exitcode;
> > > > > > > int DoExecute();
> > > > > > > Thanks
> > > > > > > TK
> > > > > > > -Brad Murry
> > > > > > > > See below
> > > > > > > > TK
> > > > > > > > ÃÆ'‚
> > > > > > > > Hello Tom,
> > > > > > > > ÃÆ'‚
> > > > > > > > Thanks,
> > > > > > > > Brad Murry
Group: DynoMotion Message: 1611 From: Tom Kerekes Date: 7/30/2011
Yes Brad I think that is reasonable.
Date: Friday, July 29, 2011, 5:47 PM
-Brad Murry
> HTH
> Sequence and ID
> -Brad Murry
> > Hello,
> > Int the case of:
> > and
> > Thanks,
> > -Brad Murry
> > > Tom,
> > > double cycle_z;
> > > int current_line;
> > > int stacki;
> > > Thank you,
> > > -Brad Murry
> > > > -Brad Murry
> > > > > See below
> > > > > int m_CurrentLine;
> > > > > int m_GCodeReads;
> > > > > int m_exitcode;
> > > > > int DoExecute();
> > > > > Thanks
> > > > > TK
> > > > > -Brad Murry
> > > > > > See below
> > > > > > TK
> > > > > > Hello Tom,
> > > > > > Thanks,
> > > > > > Brad Murry
Group: DynoMotion Message: 1612 From: Tom Kerekes Date: 7/30/2011
Hi Brad,
I'm not sure exactly what the issue is - and any Application is free to make use of the Interpreter however it wishes - but the _setup structure is basically used to save the entire internal state of the Interpreter, and the Interpreter assumes a certain coherency and relationships between the data.  So to modify things on your own would involve your application into all these internal workings which would be undesirable from an encapsulation stand point.  Also changing things on-the-fly asynchronously to the Interpreter would be even more dangerous.   So my thinking in KMotionCNC was to treat the Interpreter as a Black Box where all we need to know for example is that G21 will switch it to MM mode (which turns out to involve lots of internal conversions) the best thing for a GUI button that says "switch to MM mode" should do is submit a G21 to the Interpreter.  Admittedly, writing the 1 line disk file is hokey, but there certainly shouldn't be any performance consideration as it only happens once per User operation.
Date: Friday, July 29, 2011, 7:19 PM
Anywho-
in KMotionCNC.sln
-Brad Murry
> Having a look at
> rs274ngc.cpp
> -Brad
> > go about it.
> > implementation?
> > -Brad Murry
> > >     DoGCodeLine("G21");
> > >     DoGCodeLine("G20");
> > > Thanks again,
> > > -Brad Murry
> > > > Hi Brad,
> > > > TK
> > > > Hello,
> > > > Int the case of:
> > > > and
> > > > Thanks,
> > > > -Brad Murry
> > > > > Tom,
> > > > > double cycle_z;
> > > > > int current_line;
> > > > > int stacki;
> > > > > Thank you,
> > > > > -Brad Murry
> > > > > > -Brad Murry
> > > > > > > See below
> > > > > > > int m_CurrentLine;
> > > > > > > int m_GCodeReads;
> > > > > > > int m_exitcode;
> > > > > > > int DoExecute();
> > > > > > > Thanks
> > > > > > > TK
> > > > > > > -Brad Murry
> > > > > > > > See below
> > > > > > > > TK
> > > > > > > > ÃÆ'‚
> > > > > > > > Hello Tom,
> > > > > > > > ÃÆ'‚
> > > > > > > > Thanks,
> > > > > > > > Brad Murry
Group: DynoMotion Message: 1613 From: bradodarb Date: 7/30/2011
Hey Tom,
I hope I did not come off too abrasive. Your architecture comments make sense and are duly noted. I just thought that hey- _setup is a public member and maybe it might be cool to allow things like tool offsets to be adjusted on the fly, etc...
Of course this could be very dangerous and perhaps would allow more harm than good. I will reconsider circumventing the EMC apparatus.
Every looked into EMCrsh? It allows remote terminal command support
-Brad Murry
> Hi Brad,
> Thanks
> Anywho-
> in KMotionCNC.sln
> return;
> -Brad Murry
> > Having a look at
> > rs274ngc.cpp
> > -Brad
> > > go about it.
> > > implementation?
> > > -Brad Murry
> > > >     DoGCodeLine("G21");
> > > >     DoGCodeLine("G20");
> > > > TK
> > > > Thanks again,
> > > > -Brad Murry
> > > > > Hi Brad,
> > > > > TK
> > > > > Hello,
> > > > > Int the case of:
> > > > > and
> > > > > Thanks,
> > > > > -Brad Murry
> > > > > > Tom,
> > > > > > double cycle_z;
> > > > > > int current_line;
> > > > > > int stacki;
> > > > > > Thank you,
> > > > > > -Brad Murry
> > > > > > > -Brad Murry
> > > > > > > > See below
> > > > > > > > ÃÆ'‚
> > > > > > > > MCODE_ACTION McodeActions[MAX_MCODE_ACTIONS];ÃÆ'‚  MCodes(in GCode) can be configured to do various "Actions" such as Set/Clear a bit, Run a C Program in KFLOP, Run a Windows Program, etc.ÃÆ'‚  This structure defines what is to be performed for various M Codes.ÃÆ'‚  User Buttons also use this mechanism as "pseudo M codes" and so can be configured to do likewise "Actions"
> > > > > > > > char ToolFile[MAX_PATH];ÃÆ'‚  Can be used to define Tool Parameters
> > > > > > > > char SetupFile[MAX_PATH];ÃÆ'‚  Can be used to define inital Interpreter Settings
> > > > > > > > char GeoFile[MAX_PATH];ÃÆ'‚  Can be used to define a 2.5D Geometric correction file
> > > > > > > > int m_CurrentLine;
> > > > > > > > int m_GCodeReads;
> > > > > > > > int m_exitcode;
> > > > > > > > int DoExecute();
> > > > > > > > Thanks
> > > > > > > > TK
> > > > > > > > ÃÆ'‚
> > > > > > > > -Brad Murry
> > > > > > > > > See below
> > > > > > > > > TK
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > Hello Tom,
> > > > > > > > > bool m_InitializeOnExecute;ÃÆ'Æ'‚ÃÆ'‚ don't exportÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > bool m_Resume;ÃÆ'Æ'‚ÃÆ'‚  Set if any partÃÆ'Æ'‚ÃÆ'‚ of theÃÆ'Æ'‚ÃÆ'‚ resume sequence is desired
> > > > > > > > > double m_ResumeSafeZ; Safe Z height to be raised toÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > int m_ResumeSafeRelAbs;ÃÆ'Æ'‚ÃÆ'‚  Specifies if the Z heights are absolute or relative
> > > > > > > > > BOOL m_ResumeMoveToSafeZ;ÃÆ'Æ'‚ÃÆ'‚  Specifies whether or not the Z should be first moved up
> > > > > > > > > BOOL m_ResumeTraverseXY;ÃÆ'Æ'‚ÃÆ'‚  Specifies whether an xy motion should be made back to some position
> > > > > > > > > double m_ResumeTraverseSafeX;ÃÆ'Æ'‚ÃÆ'‚  Position in X
> > > > > > > > > double m_ResumeTraverseSafeY;ÃÆ'Æ'‚ÃÆ'‚  Position in Y
> > > > > > > > > int m_ResumeSafeSpindleCWCCW;ÃÆ'Æ'‚ÃÆ'‚  Specifies Spindle direction if it is to be re-started
> > > > > > > > > BOOL m_ResumeDoSafeFeedZ;ÃÆ'Æ'‚ÃÆ'‚  Specifies if the Z should then be fed down to some height
> > > > > > > > > double m_ResumeFeedSafeZ;ÃÆ'Æ'‚ÃÆ'‚  Specifies height Z should be fed down to
> > > > > > > > > double m_ResumeResumeFeedRate;ÃÆ'Æ'‚ÃÆ'‚  double m_ResumeZFeedRate;Specifies Rate at which feed rate should be restored to
> > > > > > > > > Thanks,
> > > > > > > > > Brad Murry
Group: DynoMotion Message: 1614 From: Tom Kerekes Date: 7/30/2011
Hi Brad,
Not at all, it is refreshing to have some new perspectives and such.  Regarding EMC: although the Dynomotion G Code Interpreter is derived from the original EMC, the Interpreter is really only a tiny piece of EMC, which is also different from the EMC2 open source project.  At some point we might like to offer an interface to EMC2.  But in some sense it doesn't make sense because I think EMC2 has a different philosophy.  It intends to do real-time control within the PC where KFLOP is designed to remove the real-time requirements from the PC.  So something like emcrsh is more an interface into a machine control rather than just an interpreter.
Date: Saturday, July 30, 2011, 12:32 PM
Hey Tom,
-Brad Murry
> Hi Brad,
> Thanks
> Anywho-
> in KMotionCNC.sln
> return;
> -Brad Murry
> > Having a look at
> > rs274ngc.cpp
> > -Brad
> > > go about it.
> > > implementation?
> > > -Brad Murry
> > > >     DoGCodeLine("G21");
> > > >     DoGCodeLine("G20");
> > > > TK
> > > > Thanks again,
> > > > -Brad Murry
> > > > > Hi Brad,
> > > > > TK
> > > > > Hello,
> > > > > Int the case of:
> > > > > and
> > > > > Thanks,
> > > > > -Brad Murry
> > > > > > Tom,
> > > > > > double cycle_z;
> > > > > > int current_line;
> > > > > > int stacki;
> > > > > > Thank you,
> > > > > > -Brad Murry
> > > > > > > -Brad Murry
> > > > > > > > See below
> > > > > > > > ÃÆ'‚
> > > > > > > > int m_CurrentLine;
> > > > > > > > int m_GCodeReads;
> > > > > > > > int m_exitcode;
> > > > > > > > int DoExecute();
> > > > > > > > Thanks
> > > > > > > > TK
> > > > > > > > ÃÆ'‚
> > > > > > > > -Brad Murry
> > > > > > > > > See below
> > > > > > > > > TK
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > Hello Tom,
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > Thanks,
> > > > > > > > > Brad Murry
Group: DynoMotion Message: 1663 From: bradodarb Date: 8/12/2011
Hello,
I am testing out the Interpreter.Interpret(args....)
and I get an error window complaining about cannot load\Gcode Programs\emc.var
Any thoughts on bypassing this?
Thank you
-Brad Murry
Group: DynoMotion Message: 1672 From: bradodarb Date: 8/13/2011
OK, so I was not exposing
CoodMotion->MainPathRoot
and
I thought it would fix this, so I imported those two public members(as well as m_Simulated).
But no dice, I am still getting the emc.var error below.
I am wondering if these char arrays are getting reinitialized somehow.
-Brad Murry
> Hello,
> Thank you
> -Brad Murry
Group: DynoMotion Message: 1673 From: bradodarb Date: 8/13/2011
It seems that CoordMotion is not a singleton and that the Interpreter uses a separate instance...
So Setting the MainPathRoot in the CoorMotion worked, but was obviously empty in the Interpreter's CoordMotion.
I will try to get the Interpreter's instance pointing to the same CoorMotion and see how that goes
-Brad Murry
> and
> -Brad Murry
> > Hello,
> > Thank you
> > -Brad Murry
Group: DynoMotion Message: 1674 From: bradodarb Date: 8/14/2011
Looking for feedback:
I am not sure whether I should set things up so that KM_Controller.CoordMotion uses the same instance of CCoordMotion as KM_Controller.Interpreter.CoordMotion
I guess I cannot decide whether there could be a possible use case where the interpreter and direct CoordMotion calls will be made on the same machine (and) possibly requiring different parameters for both(especially Motion_Params).
Any thoughts?
-Brad Murry
> -Brad Murry
> > and
> > -Brad Murry
> > > Hello,
> > > Thank you
> > > -Brad Murry
Group: DynoMotion Message: 1676 From: Neville Bonwit Date: 8/14/2011
Hi Brad,
You could make them separate instances for flexibility but then assign them to be the same in most cases, like this:
KM_Controller.CoordMotion = new CoordMotion() // Or whatever the actual syntax is
KM_Controller.Interpreter.CoordMotion = KM_Controller.CoordMotion  // If the user wanted them to be separate, they would comment out this line and uncomment the following line
//KM_Controller.Interpreter.CoordMotion = new CoordMotion()
I’m not sure if there would be problems with this approach or not, but I thought I’d throw it out there since there might be a way to make it work and it seems like it could offer flexibility and tightness of code at the same time.
-Neville
From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of bradodarb
Sent: Sunday, August 14, 2011 9:43 AM
Any thoughts?
-Brad Murry
> -Brad Murry
> > and
> > -Brad Murry
> > > Hello,
> > > Thank you
> > > -Brad Murry
Group: DynoMotion Message: 1681 From: bradodarb Date: 8/15/2011
Hello,
What I wound up doing (for simplicity and to maintain separation of concerns) was to leave the two CoorMotion intance separate, and to only expose the Motion Params pertinent to the Interpreter as properties in KM_Interpreter rather than exposing a full KM_CoordMotion as a member of KM_Interpreter.
So, use the Interpreter for interpreting and set and use CoordMotion for auxillary/Non-CNC motions.
Thanks for the feedback.
-Brad Murry
--- In DynoMotion@yahoogroups.com, "Neville Bonwit" <nevilleb@...> wrote:
> Hi Brad,
> syntax is
> I'm not sure if there would be problems with this approach or not, but I
> thought I'd throw it out there since there might be a way to make it work
> same time.
> -Neville
> Behalf Of bradodarb
> Motion_Params).
> Any thoughts?
> -Brad Murry
> --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ,
> > -Brad Murry
> > > and
> > > -Brad Murry
> > > > Hello,
> Programs\emc.var
> > > > Thank you
> > > > -Brad Murry
Group: DynoMotion Message: 1683 From: bradodarb Date: 8/15/2011
Hello,
Out of curiosity, I recieve this as the first status callback when I run any file::
0 -USE_LENGTH_UNITS(CANON_UNITS_MM)@34863.150
1 -SET_ORIGIN_OFFSETS(0.0000, 0.0000, 0.0000)@34863.150
2 -SET_FEED_REFERENCE(CANON_XYZ)@34863.150
even when I set the Set_Pointer Units property directly to Inches And/or when I add a g20 to the head of the gcode file.
Is this just a default output?
-Brad Murry
